Print Page | Close Window
Autodesk Neon renders your Revit projects
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6106
Printed Date: 17.Sep.2026 at 09:37
Topic: Autodesk Neon renders your Revit projects
Posted By: Budweiser Blog
Subject: Autodesk Neon renders your Revit projects
Date Posted: 20.Jun.2011 at 10:59
The web-cloud rendering service Autodesk Project Neon now supports not only DWG scenes from AutoCAD but also Revit projects. Project Neon comes from Autodesk Labs and it was launched about 1 year ago. Revit projects cannot be uploaded directly as RVT files but you need to install a Revit 2012 plugin which converts your scenes to an intermediate format SPD. The rendering process is then similar
Go to the http://budweiser.cadstudio.cz/2011/06/autodesk-neon-renders-your-revit.html - original post...
http://budweiser.cadstudio.cz - Budweiser Blog - CAD blog by CAD Studio
