Print Page | Close Window
Multi-sheet in shet set publish options
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6164
Printed Date: 19.Sep.2026 at 08:11
Topic: Multi-sheet in shet set publish options
Posted By: cinek
Subject: Multi-sheet in shet set publish options
Date Posted: 29.Jun.2011 at 01:02
Dear All,
I have been trying for a long time now to locate the variable responsilbe for the setting of the "Single-sheet file or multi-sheet file" option Under sheet set publish options: general DWF/PDF options-type.
It is not the Publishcollate var as this setting isd file specific ie: each sheet set file contains its own setting for this option.
Any ideas? Thanks in advance
