Updating and this popular post from a year ago. As a follow-up to the posting http://autodesk.blogs.com/between_the_lines/2010/07/how-to-change-the-autocad-layout-background-color.html - How to Change the AutoCAD Layout Background Color in response to a Twitter request, I showed how to change the Layout paper background color. But what if you just want a solid black background in Layout so that it looked like Modelspace or something easier on your eyes, here is the tip. The http://www.autodesk.com/autocad - AutoCAD default white Layout background with paper and printable area background. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0133f2481a19970b-pi"> If you want to change you http://www.autodesk.com/autocad - AutoCAD Layout background color from the defaults go to Options>Display. Now uncheck the first four Layout Elements. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0133f2481a32970b-pi"> http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0133f2481a47970b-pi"> Now select the Color button to change the AutoCAD UI element colors. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0134856d61a6970c-pi"> 1. Select Sheet Layout 2. Select Uniform Background 3. Select Color Black or whatever color you want the entire Layout background color to be. In my case I am setting it to black like Modelspace. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0133f2481a72970b-pi"> Select Apply & Close and you are done. http://autodesk.blogs.com/.a/6a00d8341bfd0c53ef0133f2481a97970b-pi"> Now you have a complete single color background Layout.
http://feeds.feedburner.com/~ff/blogs/btl?a=ojk_KyhFLRo:TUTQoRQei1o:yIl2AUoC8zA">  http://feeds.feedburner.com/~ff/blogs/btl?a=ojk_KyhFLRo:TUTQoRQei1o:qj6IDK7rITs">  http://feeds.feedburner.com/~ff/blogs/btl?a=ojk_KyhFLRo:TUTQoRQei1o:sHskjighKVI">
 Go to the http://feedproxy.google.com/~r/blogs/btl/~3/ojk_KyhFLRo/change-the-autocad-layout-background-color-to-black.html - original post...
------------- http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
