Print Page | Close Window
How to draw a spiral slide?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6191
Printed Date: 01.Nov.2026 at 01:56
Topic: How to draw a spiral slide?
Posted By: kelvin.loh
Subject: How to draw a spiral slide?
Date Posted: 04.Jul.2011 at 05:04
I want to draw a slide that goes around a cylinder like a screw thread. I have the cylinder, i have the rectangle to sweep the path. Problem now is I don't know how to draw the path itself. help please
Posted By: philippe JOSEPH
Date Posted: 04.Jul.2011 at 13:26
Hello, I suppose that you are talking about 3D.
On my 2008 release I can do 3D round springs using the command "HELIX" and then "_SWEEP" but I havn't find the way to generate springs with rectangular profile or screw threads.
I have found on the site the 3D drawing "Wood-scr.dwg" and "skrutka.dwg" that shows 3D screws.
may be you can ( and I too because I'm very interested ) ask how to do this
TO BE CONTINUED !!!
Posted By: Kajito
Date Posted: 06.Jul.2011 at 18:08
as philippe JOSEPH suggested, use the helix (specify diameter, height, no of spirals, etc), move your profile (rectangle) to the end/beginning of your spiral, and then use the sweep command.
Date Posted: 11.Jul.2011 at 03:50
Just what i needed. Thanks!
