Print Page | Close Window
Rendering Doesn't Work
Printed From: CAD Forum
Category: EN
Forum Name: 3ds Max, Maya, VRED
Forum Description: Discussion about Autodesk rendering and multimedia software, Max, Maya, VRED, Autodesk Flow platform
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6233
Printed Date: 08.Oct.2026 at 19:46
Topic: Rendering Doesn't Work
Posted By: lichterman
Subject: Rendering Doesn't Work
Date Posted: 10.Jul.2011 at 04:38
I'm trying to render using the Presentation setting and every time the rendering window pops up, renders to about 12% and then stops and erases everything it had done. HELP!
Posted By: Cad64
Date Posted: 11.Jul.2011 at 21:40
This is a Studio Max question, correct?
I'm unfamiliar with the "Presentation" setting. That sounds like Autocad to me, not Studio Max.
The settings for Mental Ray in Studio Max are Draft, Low, Medium, High and Very High. There is no Presentation setting.
Are you using Mental Ray or Vray?
Have you tried lowering your setting down to High or Medium to see if it will render at all?
Online Portfolio: http://www.rdeweese.com/" rel="nofollow - http://www.rdeweese.com/
Posted By: chupalok
Date Posted: 12.Jul.2011 at 06:11
Im currently using the 3d max, base the problem you had there's many possible why it render it stops or erase.
maybe:
1. the setup you had using vray or mental ray
2. your pc specs (lower ram)
3.maximum polygon counts
4.too much putting lights
5. higher displacement
6.etc.
by the way, what setup did you use scanline,mental ray,vray or maxwell?
long live "alpha kappa rho"
