open files
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6264
Printed Date: 21.Oct.2026 at 02:10
Topic: open files
Posted By: imcdonne
Subject: open files
Date Posted: 14.Jul.2011 at 23:52
when I try to open a file in auto cad, the open file window doesn't come up, it just tells me to type in the file in the command prompt. Anyway to fix this?!? thanks
Posted By: John Connor
Date Posted: 15.Jul.2011 at 00:41
Is FILEDIA set to 1?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Date Posted: 15.Jul.2011 at 00:43
You might as well as check to see that CMDDIA is set to 1 too.
<<AutoCAD 2015>>
Posted By: imcdonne
Date Posted: 15.Jul.2011 at 01:31
filedia did the trick!!!! Thanks, I dont know how I changed that, but it is back working now!
Date Posted: 15.Jul.2011 at 12:34
Maybe you used a poorly written custom lisp routine that reset some system variables and forgot to return them to their original settings prior to exiting.
<<AutoCAD 2015>>
