Print Page | Close Window
zoom factor
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6390
Printed Date: 05.Sep.2026 at 00:03
Topic: zoom factor
Posted By: chupalok
Subject: zoom factor
Date Posted: 09.Aug.2011 at 15:06
everytime I open the drawing the zoom factor it became 12 again i turn it 70
my question is theres any setting to become default the settings about the zoom factor?
long live "alpha kappa rho"
Posted By: John Connor
Date Posted: 09.Aug.2011 at 18:48
The value for the ZOOMFACTOR system variable is stored in the Windows Registry.  Normally, once you set it, it should not reset itself unless this is being caused by a poorly written lisp routine.  Are you using any custom lisp routines?
One way to set it and forget it would be to specify the setting in your acaddoc.lsp file.
<<AutoCAD 2015>>
