http://www.facebook.com/AutoCAD"> A big http://www.autodesk.com/autocad - AutoCAD announcement is planned to be broadcast live tomorrow, Tuesday August 16, at 10AM PDT. http://www.facebook.com/AutoCAD Check out the teaser video here: http://www.youtube.com/watch?v=4o5mw_lIcuo - Youtube video If you are on http://www.twitter.com/ - Twitter follow the hashtag https://twitter.com/#!/search/%23design816 - #design816 & http://www.twitter.com/autocad - @AutoCAD for more info. Point noted by our friend Robin down under in New Zealand that the announcement for them will actually be August 17th: http://rcd.typepad.com/rcd/2011/08/autocad-design-816.html - AutoCAD Design 8.16? . Cheers, Shaan
http://feeds.feedburner.com/~ff/blogs/btl?a=As7G_fB_aEw:YwHh4l65iyA:yIl2AUoC8zA">  http://feeds.feedburner.com/~ff/blogs/btl?a=As7G_fB_aEw:YwHh4l65iyA:qj6IDK7rITs">  http://feeds.feedburner.com/~ff/blogs/btl?a=As7G_fB_aEw:YwHh4l65iyA:sHskjighKVI">
 Go to the http://feedproxy.google.com/~r/blogs/btl/~3/As7G_fB_aEw/special-autocad-team-announcement-tuesday-august-16th-2011.html - original post...
------------- http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
