Print Page | Close Window
Block Attribute Issue
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6524
Printed Date: 31.Oct.2026 at 04:33
Topic: Block Attribute Issue
Posted By: AvisRara
Subject: Block Attribute Issue
Date Posted: 02.Sep.2011 at 21:48
Hi,
I hope someone will have an easy answer to my questions.
Here they are:
1. Is there a way I can see the attribute values of the blocks that have been inserted in my drawing without having to burst or explode them? I want to see them just temporarily while I edit the labels next to them so I can compare the values?
2. Is there a way when I click on a block to have it labelled with one of the attribute values?
I work in ACAD 2002.
Thank you very much.
Posted By: John Connor
Date Posted: 03.Sep.2011 at 12:25
I don't think there is a way to temporarily see an attribute.  It is either visible or invisible.
<<AutoCAD 2015>>
Posted By: kazoo
Date Posted: 05.Sep.2011 at 03:28
cant you copy the block, explode or burst that and then when finished with your look...delete...???
Posted By: AvisRara
Date Posted: 06.Sep.2011 at 13:25
I just hoped that there is a variable that controls whether we can or can't see the value of the attributes.
What about labeling blocks with certain values of the attributes? Is there a lisp for that?
Thank you.
Date Posted: 06.Sep.2011 at 18:16
Fields might work but the version you are using is so old it does not have this feature.  Time to upgrade?
<<AutoCAD 2015>>
Posted By: AvisRara
Date Posted: 07.Sep.2011 at 18:21
Yes, I first thought about the fields, but unfortunately our version doesn't support them.
At least I just found out that I can toggle on and off the visibility with the  ATTDISP and ATTMODE. That's all I can do, unfortunately, and no prospects of getting a newer version too...:-(
Thanks for the replies.
Date Posted: 07.Sep.2011 at 18:27
AutoCAD 2012 is the most current version.  You a few years overdue for an upgrade.  Take the wallet out dude!  LOL
<<AutoCAD 2015>>
