Problem when printing different paper sizes
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6647
Printed Date: 11.Sep.2026 at 23:23
Topic: Problem when printing different paper sizes
Posted By: MrHat
Subject: Problem when printing different paper sizes
Date Posted: 26.Sep.2011 at 10:31
Hello
I´m having an odd problem with our new printer. I have autocad 2012 running on windows 7 (64 bit) and our multifuntion printer is Konica Minolta bizhub c220.
When I print something in A3 size, everything works. When I print something in A4 size, everything works. If I print something in A3 size, then print again, "previous settings" and change the papersize to A4 the printer notifies that I should add A4 -paper to "tray 2" which is the A3 -tray. If I print first A4 and then opt for printing in A3 the same thing happens. On the latter case the printer prompts me to add A3 -paper to A4 -tray ("tray 1")
Other programs print perfectly well in such situations and also another computer with another cad, but the same printer (autocad 2009 and win xp) prints perfectly. I tried to copy the PC3 -file from the other computer that didn´t help.
Copymachines serviceman said the problem is within the cad, but shouldn´t it be on both machines then?
Edit: It seems that now I can´t print A4:s at all with this partcular computer and cad-combo. On top if it all autocad seems to think that it´s doing a smashing job. even though the printer is giving the paper-change message, the autocad-program is happily telling how well the printing went:
Job: - Plotted
Job ID: 1 Sheet set name:
Date and time started: 26.9.2011 12:09:58 Date and time completed:
26.9.2011 12:09:59 UserID: Pekka Profile ID: <<Unnamed
Profile>> Total sheets: 1 Sheets plotted: 1 Number of errors:
0 Number of warnings: 0
Sheet: - Plotted
File: L:\Tiihottarentie 4\asemapiirros
222.dwg Category name: Page setup: Device name: KONICA MINOLTA
C220PCL Plot file path: Paper size: A4
Posted By: John Connor
Date Posted: 26.Sep.2011 at 11:50
I think it is a driver related problem that came to light when you moved to a 64-bit version of Windows/AutoCAD.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
