No Properties
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6691
Printed Date: 02.Nov.2026 at 04:45
Topic: No Properties
Posted By: mrga
Subject: No Properties
Date Posted: 02.Oct.2011 at 21:59
After I start my AutoCad 2012 ,it shows error Unhandled exception c0000005 (Access Violation Reading 0x0000) at address xxxxx ,and than it shows that option Properties is incorreci.It also happends on some other versions,same as on AutoCad 2010, AutoCad Civil 3D 2012
Posted By: John Connor
Date Posted: 02.Oct.2011 at 22:58
The same error happens using three different AutoDesk products? I'd start looking at your hardware for the source of the problem. Bad memory module?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: mrga
Date Posted: 03.Oct.2011 at 10:40
I am using AutoCad 2010, but I am instal him after AutoCad 2012,
In the event that happened to me the problem with the AC2012, I have this, but the same thing, perhaps because the error in 2012. I think it's a hardware failure, just do not know solution, I have 3 gb ram memory. Any help. My English not so good, but I will cope in the event of a solution. Thanks
Posted By: edwinprakoso
Date Posted: 03.Oct.2011 at 11:44
Can you try to backup your profile, then reset it? I suspect this maybe something with docking/hiding the palette. I don't know why, but I read that docking palette can be a problem in some machine.
Edwin Prakoso
http://cad-notes.com" rel="nofollow - CAD notes | CAD tutorials and best practices
Posted By: mrga
Date Posted: 03.Oct.2011 at 16:14
I use auto hide the Properties palette. Hidden from me right when the mouse moves to the right it is activated. If you mean on that
Date Posted: 03.Oct.2011 at 18:10
Have you tried the REPAIR option at all on any of the three different programs?
<<AutoCAD 2015>>
Posted By: mrga
Date Posted: 03.Oct.2011 at 19:49
Yes, the program works 10-15 days, and again the same problem.
Date Posted: 03.Oct.2011 at 23:29
Are you using any custom lisp routines?
<<AutoCAD 2015>>
Posted By: mrga
Date Posted: 04.Oct.2011 at 00:06
I do not know what it means lisp routines simply install the program, and it happened to me. The solution is possible if you install a new system, but I want to know what the problem is. Do you think if I changed some options, for better work, etc.
Date Posted: 04.Oct.2011 at 11:56
I don't know what can be causing the problem. If REPAIR did not fix it then the next step might be an uninstall/reinstall. If you decide to do that then check the AutoDesk website for instructions on how to do the uninstall properly.
<<AutoCAD 2015>>
