Print Page | Close Window
Unblock technology previews before installing for 2012 design applicat
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6699
Printed Date: 22.Apr.2026 at 06:19
Topic: Unblock technology previews before installing for 2012 design applicat
Posted By: AliveInTheLab
Subject: Unblock technology previews before installing for 2012 design applicat
Date Posted: 04.Oct.2011 at 04:00
http://labs.blogs.com/.a/6a00d8341caed853ef014e8bb5c466970d-pi" style="display: inline;">Fotolia_33108030_XS
The Microsoft .NET Framework is a programming and run-time environment that runs on Microsoft Windows. Programs written for the .NET Framework execute in a software environment known as the Common Language Runtime (CLR). The CLR is an application virtual machine instead of accessing the hardware directly. A program written for .NET requires that the .NET framework must be installed before the new program can run. source:  http://wikipedia.org - wikipedia.org
Many of the 2012 family of products use version 4 of the .NET Framework. As http://through-the-interface.typepad.com/" target="_self - Through the Interface blogger, Kean Walmsley, has pointed out: .NET 4.0 implements slightly more stringent security than prior versions of the framework: if a Dynamically Loadable Library (DLL) is suspected as having been downloaded from the web – as is clearly the case with our technology previews – the .NET 4.0 runtime will treat that DLL as if it has been loaded from a network share. And as many of you have found out, from trying to load DLLs from network shares, this results in a reduced set of privileges on the local machine, which can often result in a load error.
The CLR has less control over hardware that is not local. Kean recommended a solution: you simply need to “Unblock” the DLL by right-clicking on it in Explorer and selecting “Properties” and “Unblock”. It’s actually better to do this for the .ZIP prior to extracting the contents, as this makes sure all files contained in the archive are unblocked.
http://labs.blogs.com/.a/6a00d8341caed853ef014e8bb5c145970d-pi" style="display: inline;">Unblock
Thanks Kean.
Unblocking a technology preview for 2012 is alive in the lab.
http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=-YySIkF_Hic:c2x5Bdnymt0:yIl2AUoC8zA"> http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=-YySIkF_Hic:c2x5Bdnymt0:F7zBnMyn0Lo"> http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=-YySIkF_Hic:c2x5Bdnymt0:7Q72WNTAKBA"> http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=-YySIkF_Hic:c2x5Bdnymt0:V_sGLiPBpWU"> http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=-YySIkF_Hic:c2x5Bdnymt0:qj6IDK7rITs">
Go to the http://feedproxy.google.com/~r/ItsAliveInTheLab/~3/-YySIkF_Hic/unblock-technology-previews-before-installing-for-2012-design-applications.html - original post...
http://labs.blogs.com" rel="nofollow - It's Alive in ihe Lab - Autodesk Labs blog by Scott Sheppard
