Print Page | Close Window
Screen Saver Lock
Printed From: CAD Forum
Category: EN
Forum Name: Civil 3D, Map, InfraWorks
Forum Description: Discussion about mapping and GIS applications Map, Civil3D, InfraWorks, MapGuide and Raster Design
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6771
Printed Date: 01.Oct.2026 at 23:15
Topic: Screen Saver Lock
Posted By: Head418B
Subject: Screen Saver Lock
Date Posted: 18.Oct.2011 at 14:47
When the password protect is checked in the screensaver dialog box and the screen saver engages, after typing in your password to reopen, autoCAD Civil3D 2012 gets an fatal error every time. If you try and restart, it just stays in the sartup dialog and runs forever. you do a cntrl-alt-del and it goes into autocad, but none of the commands work. You must reboot again to restart the computer and start all over.
BFS
Posted By: John Connor
Date Posted: 18.Oct.2011 at 15:12
Stop using a screensaver.  It is so old school.  If you don't want anyone seeing what is on your screen either turn the monitor off or do a Ctrl-Alt-Del and lock your computer.
<<AutoCAD 2015>>
Posted By: Head418B
Date Posted: 18.Oct.2011 at 15:22
Thank you for your input. I just got a fatal error attempting to do that. I have restarted Civil3D and it is stuck..once again in the start up box showing the message in the lower left corner "Preparing working environment....LAYER" and it will stay there forever if I let it. Cntrl-Alt-del 2 or 3 times will reboot the machine. I will restart and lock the computer and see if I can re-access the open drawing.
BFS
Date Posted: 19.Oct.2011 at 00:38
Maybe your install went awry.  You could try doing a REPAIR and see if that fixes the problem.
<<AutoCAD 2015>>
