Print Page | Close Window
Table
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6897
Printed Date: 02.Nov.2026 at 04:45
Topic: Table
Posted By: thiru.sta
Subject: Table
Date Posted: 16.Nov.2011 at 06:17
How to interchange the column and row in the inserted table.
Thiru
Posted By: John Connor
Date Posted: 16.Nov.2011 at 11:50
You want to change a column to a row in a table?
<<AutoCAD 2015>>
Date Posted: 16.Nov.2011 at 13:08
Sorry!..I want to interchange the column within it?
Thiru
Date Posted: 16.Nov.2011 at 13:15
Interchange the column within it?  You want to change the position of the column within a table?  The column is in the wrong place?
<<AutoCAD 2015>>
Date Posted: 16.Nov.2011 at 13:40
yes..correct..
Thiru
Date Posted: 16.Nov.2011 at 13:51
Well I know you can insert and delete rows and columns but I don't know if you can drag a column (or row) from one location in the table to another like you can in an Excel spreadsheet.
<<AutoCAD 2015>>
Posted By: Vladimir Michl
Date Posted: 16.Nov.2011 at 14:50
You can use Excel for advanced editing of AutoCAD tables - like transpositions (columns-rows) and swapping columns. AutoCAD can export tables to Excel and you can copy/paste tables from Excel or use Csv2Table (see Download) to import Excel files.
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
