How to keep my text on a block centre all the time
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6945
Printed Date: 09.Jul.2026 at 10:07
Topic: How to keep my text on a block centre all the time
Posted By: wasted03
Subject: How to keep my text on a block centre all the time
Date Posted: 24.Nov.2011 at 11:10
Hi Guys,
The problem is this, i have a block and a txt inside it. the text is in centre "justification: middle centre" also.. but when i close the cad file and open it again the text is not allign so i need to open block editor, 2x click the text then save for it to be centre again.. when i close and open again the file same problem again. hassle for me to do that always can someone help me with this? thanks in advance! btw im using CAD 2011 and CAD LT.
Posted By: John Connor
Date Posted: 24.Nov.2011 at 13:02
Could you post a copy of the block?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: wasted03
Date Posted: 25.Nov.2011 at 08:04
Hi there John. sorry but i dont know how to attached files here
Posted By: heinsite
Date Posted: 26.Nov.2011 at 08:42
I haven't been able to reproduce this problem, so we will probably need an upload to solve it.
The OP should look for the "File Upload" button in the editor.
------------- Dave Hein, P.E. Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite
