Print Page | Close Window
Autocad Shape file ...
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6973
Printed Date: 05.Sep.2026 at 04:16
Topic: Autocad Shape file ...
Posted By: amit2184
Subject: Autocad Shape file ...
Date Posted: 30.Nov.2011 at 19:09
Hello Guys,
Someone sent me a .dwg files and that must reference to some .shx (shape file). In another folder I have received the shape files also in .shx and .shp format.
My question is how to set these external shape file in Autocad setting (especially for that .dwg). Please explain me the procedure for referencing these external shape files. Please tell me command to start this process.
I just point the folder path (external shape files) under Options > Support File Search Path. I don't know whether this is right or wrong. Please let me know.
Thanks in advance.
Posted By: John Connor
Date Posted: 01.Dec.2011 at 00:22
Try the LOAD command to load the shape file.
<<AutoCAD 2015>>
Posted By: amit2184
Date Posted: 01.Dec.2011 at 03:23
Thanks for the reply,
If received shape files are the ACAD 2008 version files and I am trying to open/load the same files in ACAD 2011 version. Is that create any problem or not?
Please let me know
Date Posted: 01.Dec.2011 at 11:49
No, it should not.
<<AutoCAD 2015>>
