Print Page | Close Window
XCLIP problem
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6995
Printed Date: 03.Sep.2026 at 05:57
Topic: XCLIP problem
Posted By: irelandtoronto
Subject: XCLIP problem
Date Posted: 06.Dec.2011 at 15:27
I am having issues with the XCLIP command. When I am  finished clipping an xref, a solid triangular shape hatch appears between the vertices of the xclip boundary.
Is there anyway to correct this?
I am using AutoCAD 2012
Posted By: jemesright
Date Posted: 13.Jan.2012 at 05:35
After putting some text into the xclipboard via "xclip -i", i can run
the pastexclip command at the prompt and see text printed (i know i am
not using xclip incorrectly).
but when i use my dwm shortcut Alt+v, the text is printed not to the
current context in X, but the system console (i.e. i see it after
exiting X). Dead
any help appreciated, thanks
http://www.articsoft.com/" rel="nofollow - PGP , http://www.articsoft.com/security_encryption.htm" rel="nofollow - security software
