http;//usa.autodesk.com - Autodesk has an action packed week at http://conferences.ted.com/TED2012/ - TED 2012 and today there is the Social Space with all the great exhibits as well as the much anticipated IDEAS Cage Match tonight where cerebral heavyweights will be pitted against each other for a battle of opposing ideas in four top card matches. Master of ceremonies Jonathan Knowles http://www.twitter.com/jonathanknowles - @jonathanknowles will guide you through the evening and Autodesk fellow Tom Wujec will be the daring referee in the middle of the ring between the opponents armed only with his witty banter. The goal of this fun event is to experience the passionate opinions from both sides of the issues. Having personally attended an IDEAS Cage Match event at http://au.autodesk.com - Autodesk University 2011 I can tell you it is an experience that will surely delight both sides of your brain. No PowerPoint, no podium, no crying uncle, just the ring with you and your opponents ideas to win over the crowd. Are you ready for the Grey Matter Smackdown?
http://feeds.feedburner.com/~ff/blogs/btl?a=-eZFnXPmOiY:hqaJFOwxj-8:yIl2AUoC8zA">  http://feeds.feedburner.com/~ff/blogs/btl?a=-eZFnXPmOiY:hqaJFOwxj-8:qj6IDK7rITs">  http://feeds.feedburner.com/~ff/blogs/btl?a=-eZFnXPmOiY:hqaJFOwxj-8:sHskjighKVI">
 Go to the http://feedproxy.google.com/~r/blogs/btl/~3/-eZFnXPmOiY/autodesk-at-ted-2012-ideas-cage-matches.html - original post...
------------- http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
