Print Page | Close Window
field/ additional format/ conversion factor
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7445
Printed Date: 23.Oct.2026 at 04:36
Topic: field/ additional format/ conversion factor
Posted By: zoxie87
Subject: field/ additional format/ conversion factor
Date Posted: 04.Mar.2012 at 23:37
hi people, i need your help
when i use the field command, and want to multiply my settings, it doesn't work
ex. i use field command for making table of lenght of some objects. i need them to be in metres but the drawing unit is in cm. i use additional format / conversion factor 0.01 and it works . when i want to use it again for another object, it does't memorise the factor and i have to reset additional fomat again.
did someone have the same problem?
thank you,
z
