Print Page | Close Window
Small pdf and dwg become very large when plotted ?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7472
Printed Date: 28.Oct.2026 at 00:05
Topic: Small pdf and dwg become very large when plotted ?
Posted By: joaquin626
Subject: Small pdf and dwg become very large when plotted ?
Date Posted: 08.Mar.2012 at 20:50
Im working on windows 7 , autocad 2012
Plotter = HP Designjet T2300
The plotter is great , but some plans i have to plot (pdf or dwg) take forever (up to an hour) to load and to get plotted . When i look on the lcd interface , the file is sometimes 90 Mb when plotted . This is very strange for me because when i look at the file size in my windows explorer , my file is mostly well below 2Mb . (sometimes a 80 Kb dwg file becomes 40Mb in plotter menu) or (2Mb pdf becomes 90Mb)
Is there some things that influence that ?
I use PURGE now and then to keep my files small .
Strangely this is not with all pdf and/or dwg files.
And there is no apparent difference that i see .
Anybody that can point me in the right direction ?
Posted By: John Connor
Date Posted: 08.Mar.2012 at 23:10
Is plot spooling enabled or disabled?
How much RAM on this computer?
Did you clean out your TMP files?
<<AutoCAD 2015>>
Date Posted: 12.Mar.2012 at 10:30
Hello ,
print spooling is active .
my pc has 6Gb RAM , and 1Gb ram on vga-card .
TMP files have not been cleaned out .
Some of the xrefs in the drawings have large hatches .
Maybe this could be a reason ??
Posted By: heinsite
Date Posted: 12.Mar.2012 at 11:23
The xref's are very likely the issue.  You can easily have a file that appears to be 2 Mb, but if it has a couple of very large xrefs riding along with it they have to go to the printer too.  And that will cause the file size to balloon as far as your printer/plotter is concerned.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Date Posted: 12.Mar.2012 at 11:48
My file is about 1Mb large , all the xrefs are 5Mb together . If i Etansmit my whole drawing (with all xrefs) , my zipfile is about 8Mb , but when i plot it , the printer menu shows me a plotfile of 90 Mb ?.?..
Posted By: heinsite
Date Posted: 12.Mar.2012 at 21:29
What product are you using?  Is it AutoCAD LT, the full version of AutoCAD, or one of the verticals, specifically AutoCAD Architectural?
Dave
... sorry.  I see you've answered that above.  Still looking for an answer.
Dave Hein, P.E.
Date Posted: 21.Mar.2012 at 11:47
Nobody ??
