Print Page | Close Window
problem using cad2008 3d application (render)
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=752
Printed Date: 20.Oct.2026 at 03:13
Topic: problem using cad2008 3d application (render)
Posted By: bpbaliber
Subject: problem using cad2008 3d application (render)
Date Posted: 21.May.2008 at 09:28
i need some help from you out there. i am a filipino. i have to share with you my problem regarding autocadd 2008, i am a beginner for 3d cadd application. this happens when i am about to render the 3 storey building w/ basement. the window suddenly hangs-up or "not responding" and i cannot maneuver anymore except while it is in the 2d mode. my PC specs are to wit:
processor intel core 2 dou. mailto:E4500@2.2Ghz - E4500@2.2Ghz , 2039MB, built-in graphic cards.
OS Name Microsoft® Windows Vista™ Ultimate
Version 6.0.6000 Build 6000
Other OS Description  Not Available
OS Manufacturer Microsoft Corporation
System Name BERNIE-PC
System Manufacturer Gigabyte Technology Co., Ltd.
System Model 945GCM-S2C
System Type X86-based PC
Processor Intel(R) Core(TM)2 Duo CPU     E4500  @ 2.20GHz
, 2200 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date Award Software International, Inc. F4, 11/8/2007
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale Republic of the Philippines
Hardware Abstraction Layer Version = "6.0.6000.16386"
User Name bernie-PC\bernie
Time Zone Arab Standard Time
Total Physical Memory 2,038.94 MB
Available Physical Memory 786.81 MB
Total Virtual Memory 4.20 GB
Available Virtual Memory 1.97 GB
Page File Space 2.28 GB
Page File C:\pagefile.sys
Name Intel(R) 82945G Express Chipset Family
PNP Device ID PCI\VEN_8086&DEV_2772&SUBSYS_D0001458&REV_02\3&13C0B0C5&1&10
Adapter Type Intel(R) 82945G Express Chipset Family, Intel Corporation compatible
Adapter Description Intel(R) 82945G Express Chipset Family
Adapter RAM 256.00 MB (268,435,456 bytes)
Installed Drivers igdumd32.dll
Driver Version Not Available
INF File oem6.inf (i945G0 section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1280 x 1024 x 60 hertz
Bits/Pixel 32
Memory Address 0xE2100000-0xE217FFFF
I/O Port 0x0000C000-0x0000C007
Memory Address 0xD0000000-0xDFFFFFFF
Memory Address 0xE2180000-0xE21BFFFF
IRQ Channel IRQ 16
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\igdkmd32.sys (7.14.10.1437, 2.20 MB (2,302,976 bytes), 2/11/2008 7:36 PM)
Posted By: Capone
Date Posted: 21.May.2008 at 15:33
You may want to check out the performance tuner. '3dconfig' is the command prompt entry, or in the options>System tab. If you select the 'View Tune Log' and post that, maybe it will tell us something.
On-board graphics can be an issue when you are rendering. But I don't know for sure that it's the issue. Post the log and we'll go from there.
