Print Page | Close Window
edrw to dxf
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7689
Printed Date: 20.Oct.2026 at 06:46
Topic: edrw to dxf
Posted By: plde3
Subject: edrw to dxf
Date Posted: 18.Apr.2012 at 18:04
i need to convert an .edrw (solidworks) to .dxf or .dwg
Posted By: John Connor
Date Posted: 18.Apr.2012 at 19:53
Is there no "export" command with a DXF file type option in Solidworks?
<<AutoCAD 2015>>
Posted By: philippe JOSEPH
Date Posted: 19.Apr.2012 at 11:26
You can convert a SLDDRW 2D to DWG, it's just a "save as" XXXXX.dwg ( you choose the DWG file type in a list ).
It's recommended to do this "trough" a "transfer file" that will automaticaly transfer the different lines with your color, name and line type.
From SLDPRT and SLDASM 3D to DWG 3D you should do a "save as" XXXXX.sat with the option release 7.0 ( recommended ) then in AoutoCAD you have to "import" the XXXX.sat in a new file.
It is possible to reuse a DWG file to create a "sketch" in SLD :
In SLD, file, open ( choose XXX.dwg in a list ), choose the option create a new SLDRW + import in a new part.
From DWG 3D to SLD it's also possible directly by an "open" XXXXX.dwg.
Ask for more...
