Print Page | Close Window
STL2DWG works but can't STLOUT
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7735
Printed Date: 18.Jul.2026 at 14:57
Topic: STL2DWG works but can't STLOUT
Posted By: braneless
Subject: STL2DWG works but can't STLOUT
Date Posted: 26.Apr.2012 at 22:16
I signed up for this forum so I could use STL2DWG to edit a STL file in Autocad 2011, then convert it back to STL. I spent hours editing a file and to my horror you can't convert back to STL with STLOUT!
Basically tried CONVTOSURFACE, didn't work. Tried MESHSMOOTH, didn't work.
 Neither will create a 3d solid or a "watertight" mesh needed to convert back to STL.
Is there anything that is KNOWN to work?
Posted By: Vladimir Michl
Date Posted: 27.Apr.2012 at 09:42
STLOUT works only with solids and watertight meshes.
You can try to convert your imported mesh to solid with MESHSMOOTH and CONVTOSOLID - see http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5117 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5117  but the process fails quite often.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
