DXF manual editing help
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=790
Printed Date: 20.Oct.2026 at 03:16
Topic: DXF manual editing help
Posted By: Brawler
Subject: DXF manual editing help
Date Posted: 01.Jun.2008 at 01:41
Hi Everyone... I need some help with the DXF format. (Im using AutoCAD 2002)
What I want to do is draw let's say a square with dimension Length: 16 X Width: 720 X Thickness: 500. So this rectangular prism will be able to be viewed in 3D orbit.
I save this as a DXF and open it in notepad. What i want to do is be able to edit the dimensions manually in notepad. Is this possible? If so where do i find the place to change the lengths. I have managed to find the thickness, but can't find the others.
Eventually I want to draw more prisms in the single drawing and do the same thing with them all at once.
If it is impossible in DXF is there another format that I can use to do this? or even a different program than AutoCAD that I can do this with?
Thanks in advance.
Posted By: Vladimir Michl
Date Posted: 05.Jun.2008 at 21:32
Wouldn't it be easier to set/edit/re-create the sizes directly in AutoCAD?
------------- Vladimir Michl //CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn Autodesk Expert Elite
