Print Page | Close Window
Autodesk 360 Error – Hotfix Now Available
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7982
Printed Date: 16.Sep.2026 at 02:19
Topic: Autodesk 360 Error – Hotfix Now Available
Posted By: BetweenTheLines
Subject: Autodesk 360 Error – Hotfix Now Available
Date Posted: 14.Jun.2012 at 17:28
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19683742&linkID=9242539">Autodesk 360 Error in System Tray I experienced this myself on my system most likely due to all the pre-release versions of products I had on my machine and various version of files and file name conflicts. The issue is the https://360.autodesk.com/ - Autodesk 360 icon would error on my system tray frequently. I had been working with the QA & software development team on this to research it.
There is now a hotfix available for http;//usa.autodesk.com - Autodesk 2013 products to solve this but make sure to read the ReadMe and sign-out of http;//usa.autodesk.com - Autodesk 360 first from your app before installing the hotfix.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19683742&linkID=9242539 - Hotfix - Persistent Autodesk Sync error in the system tray
Hope this resolves the issue you may be experiencing.
Shaan
http://feeds.feedburner.com/~ff/blogs/btl?a=HUCTAq9ZL7E:6b15_g1WKqM:yIl2AUoC8zA"> http://feeds.feedburner.com/~ff/blogs/btl?a=HUCTAq9ZL7E:6b15_g1WKqM:qj6IDK7rITs"> http://feeds.feedburner.com/~ff/blogs/btl?a=HUCTAq9ZL7E:6b15_g1WKqM:sHskjighKVI">
Go to the http://feedproxy.google.com/~r/blogs/btl/~3/HUCTAq9ZL7E/autodesk-360-error-hotfix-now-available.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
