xref linework not displaying in AutoCAD lt 2006
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8
Printed Date: 20.Oct.2026 at 06:46
Topic: xref linework not displaying in AutoCAD lt 2006
Posted By: Deric
Subject: xref linework not displaying in AutoCAD lt 2006
Date Posted: 26.Jul.2007 at 20:10
We are having problems with an autoCAD lt 2004 saved drawing that was edited in LT2008. When this drawing is opened in LT 2004, some of the interior walls do not display when opened in LT 2004, but they do display in LT 2008. Is there a setting or something else that can be done to address this problem?
Thanks
------------- DERIC
Posted By: Vladimir Michl
Date Posted: 30.Jul.2007 at 16:36
Are you sure the linetypes, LTSCALE and similar settings were not changed in the LT2008 edit session?
------------- Vladimir Michl //CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn Autodesk Expert Elite
Posted By: Deric
Date Posted: 30.Jul.2007 at 17:38
I will verify that, but I don't think any of the settings were changed. I am guessing that when our LT2008 was set up, there may have been some default settings that don't correspond with our LT2006 machine. The edits I made in LT2008 were adding layers, adding linework, blocks, and text, but I didn't have to change the LTscale or any other settings. The drawings we are working on come from many different architects, I wonder if linework created in versions later than LT2006 in Xref's have problems displaying in LT2006.
------------- DERIC
