Print Page | Close Window
Properties Menu Settings
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8011
Printed Date: 29.Oct.2026 at 00:56
Topic: Properties Menu Settings
Posted By: deipriex
Subject: Properties Menu Settings
Date Posted: 21.Jun.2012 at 21:07
Does anyone know how to change the settings in the properties menu such that the area always shows up in acres instead of square feet? I have a lisp routine that does it, though the properties menu would work better for me.
-Thanks
Dead
Posted By: dabrovsky
Date Posted: 26.Jun.2012 at 17:00
UNITS command?
Posted By: deipriex
Date Posted: 26.Jun.2012 at 19:30
The DRAWING UNITS menu does not work for this. The desired output is in acres, a square area cannot be the set units for drawning. Units uses a length type specified for typical insert units.
