Print Page | Close Window
softlock manager
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8218
Printed Date: 04.Sep.2026 at 11:13
Topic: softlock manager
Posted By: designbo
Subject: softlock manager
Date Posted: 09.Aug.2012 at 22:27
Just recently moved from old location to new. In reconnecting computers,when trying to open all versions of Autocad, I get Softlock manager error, Not installed properly..
What has happened in move???
andsly
Posted By: John Connor
Date Posted: 13.Aug.2012 at 11:42
It sounds like there is a software lock on your version of AutoCAD.
<<AutoCAD 2015>>
Posted By: designbo
Date Posted: 15.Aug.2012 at 17:31
you are correct. It was a software lock so had to remove all versions of autocad and reinstall.
Now Autocad crashes on every close out of autocad 2012.. any suggestions???
andsly
Date Posted: 15.Aug.2012 at 18:25
And what happened to the software lock?  Which program was it for?
<<AutoCAD 2015>>
Posted By: designbo
Date Posted: 24.Aug.2012 at 15:20
Sorry to say it was for ALL my versions of Autocad. We run Autocad 2012, revit and MEP and all versions were locked out. Ran clean sweep on all of them and reinstalled only Autocad 2012 and seems to be working okay, but when I close out, get error message that AutoCad has quit working.......still trying to figure this one out....
andsly
Date Posted: 24.Aug.2012 at 17:19
Who installed SoftLock in the first place?
Came across this online:
"You might have to delete the license file and re-activate the software.
If the issue persists it could be related to the user permission."
What OS are you running?
<<AutoCAD 2015>>
