http://usa.autodesk.com/ - Autodesk has released a hotfix for http://www.autodesk.com/autocad - AutoCAD and the http://www.3dconnexion.com/ - 3Dconnexion devices.
- Zoom speed varies in perspective view
- Pivot point position is far from the model causing the model to go off the drawing area when rotated
- High zoom out speed after zooming in a small area of the drawing
This hotfix applies to the following products:
- http://www.autodesk.com/autocad - AutoCAD 2013
- http://www.autodesk.com/autocadlt - AutoCAD LT 2013
- AutoCAD Architecture 2013
- AutoCAD Civil 3D 2013
- AutoCAD Electrical 2013
- AutoCAD Map 3D 2013
- AutoCAD Mechanical 2013
- AutoCAD MEP 2013
- AutoCAD P&ID 2013
- AutoCAD Plant 3D 2013
- AutoCAD Raster Design 2013
- AutoCAD Structural Detailing 2013
- AutoCAD Utility Design 2013
Affected http://www.3dconnexion.com/ - 3Dconnexion Devices This hotfix applies to the following 3Dconnexion devices:
- SpaceExplorer USB
- SpaceMouse Pro
- SpaceNavigator
Consult the readme file for installation and more details.
http://autode.sk/THeiUZ" title="http://autode.sk/THeiUZ - http://autode.sk/THeiUZ
http://feeds.feedburner.com/~ff/blogs/btl?a=DY1d_RGKuXI:gA8ByYtO5us:yIl2AUoC8zA">  http://feeds.feedburner.com/~ff/blogs/btl?a=DY1d_RGKuXI:gA8ByYtO5us:qj6IDK7rITs">  http://feeds.feedburner.com/~ff/blogs/btl?a=DY1d_RGKuXI:gA8ByYtO5us:sHskjighKVI">
 Go to the http://feedproxy.google.com/~r/blogs/btl/~3/DY1d_RGKuXI/autocad-hotfix-to-correct-issues-w-3dconnexion-devices.html - original post...
------------- http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
