Print Page | Close Window
Block/Attribute Behavior Changed
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=851
Printed Date: 03.Nov.2026 at 10:18
Topic: Block/Attribute Behavior Changed
Posted By: rtsanderson
Subject: Block/Attribute Behavior Changed
Date Posted: 26.Jun.2008 at 18:17
I have created a number of blocks for electronic components. Each block contains the component outline and an attribute for the component designation. The outline is grouped, the designation is not contained in the group.
Up until recently, the blocks have worked as follows - When I insert the block, I am prompted for the designation. If I enter one, it appears on the component. If I don't enter one, nothing appears on the component. If I explode the block, the attribute tag is displayed and I can move the tag separately from the component. The component is still grouped.
Sometime in the last few days, the behavior of the blocks has changed. Now, when I enter a block, I am not prompted for the designation. The part is inserted immediately, the attribute tag is displayed, and the component is ungrouped. This behavior is the same for all blocks. I've been using the same blocks and templates for years.
Can anyone explain why the behavior has changed? Any help will be greatly appreciated.
I am using AutoCAD LT 2005
Bob Sanderson
http://bobsanderson.com - bobsanderson.com
Posted By: Vladimir Michl
Date Posted: 27.Jun.2008 at 15:48
The attribute prompts can be suppressed by the ATTREQ variable. See:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5649 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5649
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Date Posted: 27.Jun.2008 at 16:00
I've already tried that. It didn't work.
Bob Sanderson
