Print Page | Close Window
id command
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8588
Printed Date: 03.Sep.2026 at 23:58
Topic: id command
Posted By: dabrovsky
Subject: id command
Date Posted: 08.Nov.2012 at 12:09
hi all,
Need quick help, my cad settings went completely wrong…
I’ve used to use a lot ID command in paper space to check coordinates of the object in model space, but from now on I need to go to model space through viewport to extract X,Y,Z. Each time I check coordinates it gives me x,y,z values related to 0,0,0 at paper space
Any suggestions very welcome
Thanks
chris
Posted By: philippe JOSEPH
Date Posted: 08.Nov.2012 at 12:24
Hello, check if your UCS in your viewport when you open it is set on General and not on an UCS with a setting OK for the configuration of your viewport.
There is an interesting Block right here in the CAD Block library interesting for you : VertID.dwg wich is writing X an Y coordinates automaticaly when you insert it ( or at least the first that you insert is not working but the 2nd , 3rd etc... yes ). You should try it.
I have done an updated version of it includind the Z location, the Z automatic text is not working but it's still of a good use, ask for it if needed.
