Print Page | Close Window
Viewport issues
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8735
Printed Date: 21.Oct.2026 at 02:09
Topic: Viewport issues
Posted By: saruparu
Subject: Viewport issues
Date Posted: 13.Dec.2012 at 17:09
Hi all,
I am experiencing some issues on Autocad. I been working on an assignment, and have two layouts for my drawings. First layout is elevation views and second layout is for details. On my details view I activate the view ports and add in dimensions, and same with my elevations views. However for some reason some of the dimensions I put in on the details views are now showing up on my elevation layout. The rest of the dimensions are fine and in their corresponding layouts. How can I fix this problem so I do not have other dimensions showing up on the wrong layout?
Posted By: John Connor
Date Posted: 13.Dec.2012 at 18:05
You could do all your dimensioning in the layout instead of in model space.
<<AutoCAD 2015>>
Posted By: saruparu
Date Posted: 13.Dec.2012 at 20:29
I did do them in the layout!none of the dimensions were done on model space.. all dimensions were done in different view-ports
Posted By: Frankangie
Date Posted: 13.Dec.2012 at 21:45
Try to show annotative objects only for the current scale.
Date Posted: 14.Dec.2012 at 11:36
You might have been in a layout when you added your dimensions but it sounds to me as though you were adding them THROUGH a viewport which means your dimensions would be in model space.  How else would you explain that dimensions that you don't want to see are appearing in a different viewport?
Are you utilizing annotative scaling?
<<AutoCAD 2015>>
