Print Page | Close Window
how to explode spline and an arc?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8790
Printed Date: 22.Oct.2026 at 09:54
Topic: how to explode spline and an arc?
Posted By: amit.simplex
Subject: how to explode spline and an arc?
Date Posted: 29.Dec.2012 at 05:59
Hello all,
Please give me an solution about to explode an spline and an arc. in auto CAD. i am using auto CAD 2008 Civil 3D Currently. URGENT...
Regards.
Posted By: heinsite
Date Posted: 29.Dec.2012 at 06:11
If the spline and arc are joined as a single polyline object, type X or EXPLODE at the command line, select the object, and hit the Enter key.  The spline and arc objects will now be separate objects.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Date Posted: 29.Dec.2012 at 06:34
Thanks for your reply..but if i am just explode an spline  line by x command. it is performed noting. Please Help.
Posted By: heinsite
Date Posted: 29.Dec.2012 at 06:54
A spline is a single object unless or until you convert it into a polyline.  If you want to do that you can use the PEDIT command and select the spline.  Choose a precision value and enter.  Now you will end up with an object you can explode.
Caution however:  You'll end up with very small segments!
Dave.
Dave Hein, P.E.
Date Posted: 29.Dec.2012 at 07:00
T
Thanks....i got it.
Posted By: PeteLnB
Date Posted: 02.Jan.2013 at 11:10
Hello
You can also use SPL2PL to convert splines to polylines.
This function is in newer versions (2011, 2012, 2013) and it was avalible for free to download from ACAD net site allready before (as spl2pl.vlx). You had to APPLOAD this application so you could use it.
