Print Page | Close Window
The type of the line is changed in the layout
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8813
Printed Date: 05.Sep.2026 at 19:37
Topic: The type of the line is changed in the layout
Posted By: FrauSand
Subject: The type of the line is changed in the layout
Date Posted: 04.Jan.2013 at 16:11
Hi guys,
i have a problem:
I have drawn a line (insulation), I scaled it so as I need it and it looks good. But in the layout window, where I have everything set for the printing (plot), there the line is so much bigger!! Why? And if I change the line in the layout window, it also changes in the "Model" and then do nothing fits together.
Cry
HELP!
Posted By: John Connor
Date Posted: 04.Jan.2013 at 18:50
Look at the system variables LTSCALE, PSLTSCALE and MSLTSCALE.
By the way, it is not the "type of the line" it's the scale of the line type.  There is a difference.
<<AutoCAD 2015>>
Posted By: admann27
Date Posted: 05.Jan.2013 at 09:43
As mentioned before, it's all about PSLTSCALE variable.
In your case, if the scale of the line is OK in Model space, just run the command "PSLTSCALE" and the set it to 0 (zero).
Then check it in paper-space. If it still looks different, try the "REA" (regen all) command.
Posted By: FrauSand
Date Posted: 05.Jan.2013 at 18:31
Thank you!!!!!!!!!! Its works!!!!!!
