Print Page | Close Window
Change text case in entire drawing
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8842
Printed Date: 04.Nov.2026 at 00:12
Topic: Change text case in entire drawing
Posted By: Anders79
Subject: Change text case in entire drawing
Date Posted: 12.Jan.2013 at 13:10
Hi.
I have this huuuge drawing - a city map - and for some unknown reason  half of it  have street names, block names, and all other texts written with upper- and lower case, and the other half of the map is just written in caps. can I somehow change all letters to caps without having to edit each text?
It realy doesn't matter, but it looks ugly...
Command: oops
Posted By: LatCh
Date Posted: 12.Jan.2013 at 18:40
Try the [CMD]TCASE[/CMD] command. It should do the trick.
Posted By: heinsite
Date Posted: 12.Jan.2013 at 23:14
TCASE is a good suggestion.  Combine it with QSELECT to grab all the text and mtext in the drawing (separate operations, append the second selection to the first set of results) and convert the text case as you like.
However... TCASE is an Express Tool.  It will not be available in LT versions.  You'll need to have the full version of AutoCAD with the Express Tools installed to use this command.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Posted By: John Connor
Date Posted: 13.Jan.2013 at 19:15
You would have to use a macro.  I'm sure you could easily find one posted either here, at the CADTutor website, The Swamp website, or at the Cadalyst magazine website.  I may have one at work but if I do I won't be able to post it until Monday morning.
<<AutoCAD 2015>>
Posted By: heinsite
Date Posted: 13.Jan.2013 at 22:23
Wow.  It looks like the format here changed overnight.  So far so good.
Embarrassed
Dave Hein, P.E.
Date Posted: 15.Jan.2013 at 10:43
I could not find the macro, sorry.  It was from a fairly long time ago and I just may have failed to copy it forward as I continued to upgrade to new releases.
<<AutoCAD 2015>>
