Print Page | Close Window
saveing 2000 lt dwg in 2011 lt
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8862
Printed Date: 02.Nov.2026 at 14:30
Topic: saveing 2000 lt dwg in 2011 lt
Posted By: snoberger
Subject: saveing 2000 lt dwg in 2011 lt
Date Posted: 18.Jan.2013 at 02:14
I use autocad lt 2000 now Ihave autocad lt 2011 how do I save my 2000 lt dwg into 2011 lt
I get a message that says you do not have permission to save to this locationCry
Posted By: heinsite
Date Posted: 18.Jan.2013 at 06:25
Are you running your AutoCAD program on a networked system or a single user system?
If you can load and change the old 2000ver file in AutoCAD 2011 you should have no problem saving it again as either a 2000 file or a 2010 file (the native file format of AutoCAD 2011).
Dave
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Posted By: Vladimir Michl
Date Posted: 18.Jan.2013 at 11:24
This is probably only a problem of access rights to your disk folders. AutoCAD DWG files are fully compatible "upwards" (so version 2011 will load your 2010-files).
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Posted By: John Connor
Date Posted: 18.Jan.2013 at 11:34
Are you on a network?
<<AutoCAD 2015>>
Date Posted: 18.Jan.2013 at 13:36
I am not on a network.
Date Posted: 18.Jan.2013 at 13:38
single user system
Or perhaps saving to another user's folders? Or saving to \Program Files or to the root folder of your disk?
Vladimir Michl
Date Posted: 18.Jan.2013 at 14:04
my 2000 lt is in XP and my 2011 lt is in window 7
Posted By: heinsite
Date Posted: 19.Jan.2013 at 08:22
We still don't know much about your problem.  If you load the 2000 file into AutoCAD 2011 you don't have any problems with the drawing, right?  What happens if you "save as" this file as a 2010 version file to the same directory as the original file?  What about save as to a newly created drawing folder?  Do you continue to get the "no permission" error?
Dave.
Dave Hein, P.E.
Date Posted: 19.Jan.2013 at 12:24
What version of Windows 7 are you running?  Example: Home Edition
Is Windows 7 32-bit or 64-bit?
Are you running WinXP in a virtual machine?
I am assuming WinXP is 32-bit.  Am I correct?
This sounds like a "permissions" problem to me and it does not have anything to do with the drawing file itself.
I currently run Win7 Ultimate 64-bit and have both 32-bit versions and 64-bit versions of AutoCAD running on the same computer.  And I have only one folder that I store all my drawings in.
<<AutoCAD 2015>>
