Print Page | Close Window
Preventing AutoCAD from plotting hidden objects
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8901
Printed Date: 20.Oct.2026 at 22:17
Topic: Preventing AutoCAD from plotting hidden objects
Posted By: fsurf02
Subject: Preventing AutoCAD from plotting hidden objects
Date Posted: 28.Jan.2013 at 22:34
Hello All,
I have what I thought was a simple problem, but have been unable to get any answers to using a simple google search.  Hopefully someone here can give me a hand.
Essentially I found the HIDEOBJECTS command today (on google no less) and have been using it to clean up a surveyor's drawing I received to only show the pertinent data I want to see.  I have also turned off several layers as well, but some of the objects I want to turn off belong on layers I want to keep on (thus the need for the HIDEOBJECTS command).
Anyhow, everything works fine besides when I go to plot the drawing (I export it to a PDF typically).  I don't want these items to show up on my exported PDF either but there they are.  Am I dense and missing something obvious, or is there not a way to do this?  I figured there would be a check box to click in the plot options portion of the page manager, but I can't seem to find anything.
Any help would be greatly appreciated!!
AutoCAD 2011
Windows 7 64 bit
Posted By: Vladimir Michl
Date Posted: 29.Jan.2013 at 09:34
See the [CMD]PAGESETUP[/CMD] command or the PLOT options - shaded viewport.
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
