Print Page | Close Window
L command
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8951
Printed Date: 03.Nov.2026 at 22:59
Topic: L command
Posted By: awoakes1@msn.com
Subject: L command
Date Posted: 13.Feb.2013 at 18:46
I'm using ACAD 2009 and my line command is somehow not working. Maybe I have turn off some toggle on the keyboard.  I'll enter l command, pick a first point then move to a second point, enter, and the line will not remain. Thanks for any help
Posted By: Vladimir Michl
Date Posted: 13.Feb.2013 at 20:11
Please note that L is not a command, just a shortcut (alias) so it depends how you have it mapped. The the standard _LINE command.
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Posted By: CarlB
Date Posted: 13.Feb.2013 at 21:01
Is your current layer turned on?
Posted By: John Connor
Date Posted: 13.Feb.2013 at 23:40
Are you sure you're not drawing on a layer that is turned off?
<<AutoCAD 2015>>
