Print Page | Close Window
Linetypes Not Plotting
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8975
Printed Date: 29.Oct.2026 at 02:33
Topic: Linetypes Not Plotting
Posted By: FSA_AP
Subject: Linetypes Not Plotting
Date Posted: 20.Feb.2013 at 01:02
Our office has just upgraded to AutoCAD LT 2013 and are having a boat-load of problems. One major one is that none of our assigned linetypes will plot correctly. For instance, when I'm drawing a building section at 1:1 in model space it shows our hidden lines correctly displayed as a dashed linetype, but when I create a new layout for a half-size print (11x17) and set the drawing to be scaled at 1/4"=1'-0" when I click on the layout tab to plot the drawing the lines look solid and end up printing solid as well. When I type in the LTSCALE command it says that it's properly scaled at .2500 inches (1/4") and PSLTSALE command set at 1. So, I can't figure out why the linetypes won't print correctly. It could possibly be our assigned printer settings or an issue with our .CTB standards, but I can't seem to find anything wrong with those.
If anyone has any insight to this it would be greatly appreciated.
FSA_AP
Posted By: heinsite
Date Posted: 20.Feb.2013 at 03:29
If you're setting custom linetype scales you will often run into display problems like this.  The general rule of thumb to start with is always the following:
LTSCALE=1
MSLTSCALE=1
PSLTSCALE=1
Dave
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
