Print Page | Close Window
∅ Ø ¥ DIAMETER SYMBOL
Printed From: CAD Forum
Category: EN
Forum Name: Civil 3D, Map, InfraWorks
Forum Description: Discussion about mapping and GIS applications Map, Civil3D, InfraWorks, MapGuide and Raster Design
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9020
Printed Date: 03.Nov.2026 at 17:32
Topic: ∅ Ø ¥ DIAMETER SYMBOL
Posted By: philippe JOSEPH
Subject: ∅ Ø ¥ DIAMETER SYMBOL
Date Posted: 05.Mar.2013 at 15:05
Hello everybody.
We have just move from AutoCAD 2008 32 bits to AutoCAD 2012 64 bits and I have lost my Ø ( Alt+157 ).
Now when I type Alt+157 I get ÂĄ  and not Ø.
I still have the possibility to have ∅ with %%c but I don't like it.
I still have the possibility to copy/paste Ø from an old file but it makes me thinking that it still must be available directly, but where ?
Posted By: John Connor
Date Posted: 05.Mar.2013 at 18:23
Probably because you are still using DTEXT not MTEXT.
MTEXT allows the insertion of the diameter symbol.
<<AutoCAD 2015>>
Posted By: Vladimir Michl
Date Posted: 05.Mar.2013 at 18:47
The code %%c is just the right way to enter the diameter symbol. You can also use \U+2205 to enter the Unicode "empty set" character (similar to diameter). Or you can use the Alt combination to enter "O-slash" character in your current codepage. But the respective Alt combination (numbers) will vary depending on your current Windows codepage and the keyboard layout you are switched to. There is no difference in AutoCAD itself.
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Posted By: Novarese
Date Posted: 05.Mar.2013 at 19:24
It doesn't matter, Joe: you can get the diameter symbol in DTEXT too.
@ Philippe: try ALT + 0248
Wink
Date Posted: 06.Mar.2013 at 07:45
Hello everybody, thanks for your replies even if I had declared my question in Inventor instead of AutoCAD ( I don't know how I've done this and I suppose that I have to thank Vladimir for having re-declared it correctly ).
Ø ( ? ) versus ∅ ( \U+2205 or Alt+0248 ), I still have the problem but I still can copy/paste Ø from an old file.
I have tried Alt+XXX up to Alt+520 ( I will try Alt+0XXX to see what's happening ).
Is there a place where all these allias are listed ?
Posted By: Novarese
Date Posted: 06.Mar.2013 at 09:41
http://www.siongboon.com/projects/2007-12-08_ascii_code/index.htm" rel="nofollow - http://www.siongboon.com/projects/2007-12-08_ascii_code/index.htm
Date Posted: 06.Mar.2013 at 12:17
Hello Novarese, ho trovato quello che cercava e molto piĂą cioè :
Ø = Alt+0216.
Grazie mille.
Posted By: Novarese
Date Posted: 06.Mar.2013 at 14:51
Il n'y a pas de quoi, Monsieur :)
