Print Page | Close Window
Compare DWG File Changes in AutoCAD
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9029
Printed Date: 16.Sep.2026 at 17:45
Topic: Compare DWG File Changes in AutoCAD
Posted By: BetweenTheLines
Subject: Compare DWG File Changes in AutoCAD
Date Posted: 07.Mar.2013 at 10:34
Have you ever ended up with two drawings of the same name, just different time stamps on the file or an added suffix on the file name? Perhaps another team member was trying to be helpful (or not) and edited the file and you need to know what changed? Lucky for you there is an Autodesk App for that, and FREE.
Go to the http://autodesk.blogs.com/between_the_lines/2013/03/compare-dwg-file-changes-in-autocad.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
