Print Page | Close Window
AutoCAD Reference File Management
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9072
Printed Date: 17.Sep.2026 at 02:03
Topic: AutoCAD Reference File Management
Posted By: BetweenTheLines
Subject: AutoCAD Reference File Management
Date Posted: 21.Mar.2013 at 16:09
How can you update and re-path AutoCAD drawing reference files such as other drawing files, fonts, or plot configuration files after a path has changed without launching AutoCAD? Use the stand alone Reference Manager AutoCAD drawings can reference several types of external files including other drawings (XRefs), images, fonts, images, PDF, DWF, DGN underlays, and plot configurations. The paths to these referenced files are saved in each AutoCAD drawing.
Go to the http://autodesk.blogs.com/between_the_lines/2013/03/autocad-reference-file-management.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
