plot multipe viewports at the same time
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9080
Printed Date: 28.Oct.2026 at 00:05
Topic: plot multipe viewports at the same time
Posted By: Buildingsagent
Subject: plot multipe viewports at the same time
Date Posted: 26.Mar.2013 at 11:04
Hi,
How can I print multiple viewports in one time.
Eerlier (acad 2004) I can select multiple viewports with 'ctrl-key', right mouse-buttom plot ect.
In Acad 2012 it isn't possible... Maybe something others possible...?
Tanks aloth, Jo
Posted By: John Connor
Date Posted: 26.Mar.2013 at 17:15
Either use the Sheet Set Manager or the Publish command would be my first two guesses.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Date Posted: 27.Mar.2013 at 10:38
Could you clarify... Don't understand it... How can I do it...?
Posted By: heinsite
Date Posted: 27.Mar.2013 at 13:01
Put those viewports in paper space (on one of the Layout tabs). Then when you print that Layout you'll see as many viewports as you placed there. This is the beauty of Layouts. They're made for customized printing.
Dave.
------------- Dave Hein, P.E. Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite
