Offset command problem
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9130
Printed Date: 02.Sep.2026 at 22:40
Topic: Offset command problem
Posted By: BradleyRobertson
Subject: Offset command problem
Date Posted: 11.Apr.2013 at 15:13
Problem with offset command in Autocad9LT - I have the same 64 bit version of AutoCAD 9 LT on 2 identical Compaq CQ5814 computers. Each is running Windows 7 64bit and each has 6gig of memory. I have used this version of AutoCAD for over a year. Both operated fine until recently on one computer, each time I try to use the OFFSET command (by icon or by typing command) as soon as I try to insert a number for the offset and enter, the drawing is exited back to desktop. It only happens on one computer. This computer had worked fine until recently. I think some other program has an interference with the CAD command. How do I find out which one? I can delete programs one at a time to see which one has the interference but this is a long process. Any HELP?
Posted By: John Connor
Date Posted: 11.Apr.2013 at 18:10
Other than anti-virus programs that get overly aggressive analyzing files I can't think of another program (unless it is an AutoCAD add-on) that would interfere with one command in AutoCAD.
Just do a Repair of the install.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
