Print Page | Close Window
Slicing 3d, but not solid
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9169
Printed Date: 03.Nov.2026 at 15:33
Topic: Slicing 3d, but not solid
Posted By: Jegius
Subject: Slicing 3d, but not solid
Date Posted: 22.Apr.2013 at 09:36
Hi, i am newbie in autocad 3d modeling. I have downloaded 3d engine model in .stp format and converted it to .dwg.. now trying to get 2d section planes from it.
That is how 3d model looks like in autocad :  http://img837.imageshack.us/img837/9577/blockreference.jpg" rel="nofollow - http://img837.imageshack.us/img837/9577/blockreference.jpg
And this is example of what i need to get from 3d model:  http://img248.imageshack.us/img248/7899/sectionplane.jpg" rel="nofollow - http://img248.imageshack.us/img248/7899/sectionplane.jpg
I think that i can't get that kind of drawing from 3d model, so i would be satisfied if i could get just section plane with exact measurments.. I tried tu use SLICE function, but it slices only solid object.. And i can't convert it in to the solid (i get message : objects cannot be converted '')
Any help? any ideas?
Posted By: John Connor
Date Posted: 22.Apr.2013 at 11:46
You'll have to try to convert it to a solid.  What is it now a mesh?
<<AutoCAD 2015>>
Posted By: Jegius
Date Posted: 22.Apr.2013 at 12:51
I'm attaching a link to .dwg file with one part of that engine, maybe it will be more simple.
http://www.2shared.com/photo/XuAaaAGF/Filter.html
Date Posted: 22.Apr.2013 at 13:22
You won't be able to do much using AutoCAD 2007.  Too old.
Try Inventor or Inventor Fusion.
<<AutoCAD 2015>>
Posted By: Jegius
Date Posted: 22.Apr.2013 at 14:58
i have autodesk inventor fusion.. but it didn't helped me... probably because i dont know how to use it.. now trying to download autocad 2014.
Date Posted: 22.Apr.2013 at 15:40
Is the object comprised of surfaces, a mesh, splines or just regular polylines?
It sounds as those you might have to convert the object to a 3D solid first.
<<AutoCAD 2015>>
