Print Page | Close Window
PDMODE
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9225
Printed Date: 02.Nov.2026 at 04:59
Topic: PDMODE
Posted By: rathome
Subject: PDMODE
Date Posted: 18.May.2013 at 03:06
PDMODE doesn't seem to work on my AutoCAD 2013 program. Every time I check it is set to 35, but when dividing a line, the point is always a dot.
Posted By: heinsite
Date Posted: 19.May.2013 at 11:09
Points will plot as a dot if you're on the DEFPOINTS layer.  Get off of that if that's where you are and you should be fine.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Posted By: Kent Cooper
Date Posted: 20.May.2013 at 14:37
Check your PDSIZE value, too.
Posted By: heinsite
Date Posted: 20.May.2013 at 14:48
Regardless of PDSIZE or PDMODE a point will still display as a dot if it's on the DEFPOINTS layer.
Dave.
Dave Hein, P.E.
