Print Page | Close Window
Discrepancy in .pdf and Plot Output
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9253
Printed Date: 02.Nov.2026 at 04:59
Topic: Discrepancy in .pdf and Plot Output
Posted By: GHiatt
Subject: Discrepancy in .pdf and Plot Output
Date Posted: 29.May.2013 at 17:21
I work in an environment where I need to share drawings with others who cannot view drawing files.  I have a series of title blocks created that will plot to the extents of the paper (usually 8.5x11).  However, when I export the same paper space layout to .pdf, I lose approximately 1/4" of the top of my layout, and 5/8" of the right side of my layout.  If I resize the title block, and position it correctly, the .pdf will include the entire layout, but I would like the TB to remain in it's original (larger) size.  I have tried the page setup in the Output panel, but with no luck.  I would appreciate any advice.
GRHiatt
Posted By: beej13
Date Posted: 29.May.2013 at 23:06
Hi, You need to set your printer margins (printable area) to 0 in your page setup for that paper size and save your settings, hope that helps.
Posted By: GHiatt
Date Posted: 30.May.2013 at 14:22
beej13,
Thanks for the info.  Are you referring to the page setup in ACAD, or Adobe?  I was able to change my paper size to ANSI Full Bleed A, which will give me nearly everything I need (missing the outermost border, but not the title block or content of the drawing).  This is better, but still not quite what I am looking for.
GRHiatt
Posted By: GHiatt
Date Posted: 30.May.2013 at 15:24
beej13,
After further fiddling, I found the settings that you described.  Everything is working perfectly!
Thanks for the info.  This forum is great!
GRHiatt
