Print Page | Close Window
Autocad 2014
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9257
Printed Date: 10.Jul.2026 at 21:12
Topic: Autocad 2014
Posted By: kenjg
Subject: Autocad 2014
Date Posted: 30.May.2013 at 17:17
Hello All,
I have some general questions which I can't seem to find and answer on the net.
1. I used ACAD 2009 previously and when I double clicked a line/circle, the Properties Box opened.  In ACAD2014, the Quick Properties Box opens.  Can I change it NOT to open the Quick Properties and just open the standard Properties Box?
2. When double click on a Dimension in A2014, it shows me to edit the text in that dim.  A2009 the Properties Box opened.  Can I change this so it works like 2009?
3.  When I create a dim a2014 and it is NOT centered/aligned, it does NOT show using right-click like a2009 to HOME/center the text.
Please ask if more questions are needed.  Sorry for being vague on my questions.
Thank you & Best Regards
KenJG - ACAD2014
Posted By: Vladimir Michl
Date Posted: 30.May.2013 at 18:15
The points 1 and 2 can be solved by setting the appropriate double-click action. Open the CUI editor and set the required command (e.g. Properties) for double-click actions on specific object types. Just drag it from the bottom command list to the object type list.
ad 3) the Home text function is available directly on the text-grip (hoover over it and choose the last function from the list)
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
