On July 24, the DesignScript team provided me with an update of the technology preview. This update is build 0.6.46.9306 and includes defect corrections based on your feedback:
You can check out the new release for yourself via the Autodesk Labs site:
- Node previews for simple literal values (e.g. "10") are no longer shown.
- Node previews can now be toggled globally with a single menu option.
- Performance surrounding node selection has been greatly enhanced.
- Performance of node rendering has been improved.
- Comments are supported in Code Block node, so a code block with comment can serve as comment node for the moment.
- DesignScript Studio documentation link is added and can be found under Help>Introduction to Studio
- Improved support for Replication guides.
- Improved error handling for the import .ds file.
- Events Support: Property changed notification events from external library can be used to trigger update in DesignScript when an object property has changed
http://labs.autodesk.com/utilities/designscript" target="_self - // Download DesignScript for AutoCAD 2014 or AutoCAD 2013
Please keep that feedback coming in. You can see from the corrected defects list that your efforts are making a difference. You can reach the team in a variety of ways:
Amelioration is alive in the lab.
http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=if3AyeYVx7c:H-OwkK92BFk:yIl2AUoC8zA">  http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=if3AyeYVx7c:H-OwkK92BFk:F7zBnMyn0Lo">  http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=if3AyeYVx7c:H-OwkK92BFk:7Q72WNTAKBA">  http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=if3AyeYVx7c:H-OwkK92BFk:V_sGLiPBpWU">  http://feeds.feedburner.com/~ff/ItsAliveInTheLab?a=if3AyeYVx7c:H-OwkK92BFk:qj6IDK7rITs">
 Go to the http://feedproxy.google.com/~r/ItsAliveInTheLab/~3/if3AyeYVx7c/updated-designscript-now-available-on-autodesk-labs.html - original post...
------------- http://labs.blogs.com" rel="nofollow - It's Alive in ihe Lab - Autodesk Labs blog by Scott Sheppard
