Print Page | Close Window
123D Design Challenge Enter Now
Printed From: CAD Forum
Category: EN
Forum Name: RSS Feeds
Forum Description: Automatic publishing of CAD information from other web sources
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9572
Printed Date: 19.Apr.2026 at 06:16
Topic: 123D Design Challenge Enter Now
Posted By: BetweenTheLines
Subject: 123D Design Challenge Enter Now
Date Posted: 23.Aug.2013 at 08:05
The Autodesk 123D Design Challenge has started and you have 50 days to submit your entry and gain fame and fortune, ok maybe just some 3D street cred. This is open for all ages and most countries worldwide. You can see the entries as they are entered to get inspiration or to cause you to amp up your entries awesomeness levels. You could even win a 3D printer. Go create your 3D project and show others how you created it using Instructables before October 12th 2013. http://bit.ly/178GzXP
Go to the http://autodesk.blogs.com/between_the_lines/2013/08/123d-design-challenge-enter-now.html - original post...
http://autodesk.blogs.com/between_the_lines/" rel="nofollow - Between the Lines - Autodesk blog by Shaan Hurley
